engine break down help
ive been systematically going through every part of my engine and im ready to crack the case and 2 things are stopping me for right now.
1. the magneto magnet seems to be hanging up on the shaft, do i just use a puller or is there a trick to getting this off? it slides up easily and then just stops.
2. is there a special way to remove the drive gear that connects to the clutch gear? its got a slot for a screwdriver but that cant be right.
thanks
Here it is:
A photo of the tool is shown below: It is a universal tool for removing the drive sprocket, the clutch gear, and the crank gear. Yes that is a slotted screw holding the crank gear to the crank.
Yes, use a puller to remove the magnet. Be carefull, this end of the crank is small in diameter and easily damaged.
Here's a link to the tool.
Puller
Jim
i read that thread and it dident cover what i needed to know. i have the puller it came with my kit and ive been using it, i just need to know how to get the magneto magnet off and that drive gear. i presume that i have to get like a gear puller to get the magneto magnet off and for the drive gear do i just take a screw driver to it?
