FlyingSchwinn
I have been having this issue since the motor was new, let me explain. Engine will start out fine, lots of power, etc and then after a while will develop a severe lack in power all the way through the power band. It will happen after running over half throttle and going up hills; both are situation when more air and fuel are needed. I thought I solved the problem with the change to an NT Speed carb because the motor is a 66cc. I was thinking either a warped head, bad plug, wrong jet size, or an air leak. Before troubleshooting I need opinions. These engines are cheap and poorly made and I wasnt expecting much but they are simple to repair. Any input is appreciated, thx.
