Eliminate the Muffler
Cycofast
22
Indiana
So I realize that I'm relatively new to the world of motorbicycling, but I'm fairly well grounded in thermodynamics. What I'm getting at is removal of the muffler on my chinese kit engine to maximize efficiency. The only down side that I can think of would be the ridiculously loud noise as I roll down the street. If you think about it, this might a) create awareness for cars and b) make my bike sound like a real motorcycle. Of course there is the Police factor, but we'll cross that bridge when it happens.
Also a straight pipe exhaust may be an alternative to no muffer at all.
Your thoughts?
Cycofast
22
Indiana
Is this really true? I have seen some aftermarket mufflers that have been elongated; wouldn't this effect the "back pressue" ? I guess what I'm saying is that if P and V are proportional, wouldn't the longer muffler negatively impact the P if back pressure was necessary?
Thanks for the feedback.
spad4me
472
Arizona Bullhead
Would V = Volume and and and P= Police
Ghost0
763
Bellingham, WA
2 stroke engines are very sensitive to exhaust pressure, size and shape. Because they have no valves like a 4 stroke, the exhaust if built correctly, will act like a valve and increase performance over no exhaust at all. 4 strokes on the other hand pretty much could care less about their exhaust as long as it is not restricting flow. So by eliminating your exhaust you will not only decrease the performance of your engine you will not make any friends in the community.
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
No muffler= great wide open full throttle performance, no idle, very bad throttle transition from idle to wide open or anywhere in between.
mwsbrewn
New Hapshire
Think of a mufflers exhast like an ocean wave. When it exits the muffler, a wave of exhast re-enters as the piston drops, sucking it back in the chamber and this adds to the pressure. Its the pressure the forces the piston down again causing power. So a muffler can do more than just muffle.
bairdco
a guy who makes cool bikes
Aug 18, 2009
6,537
264
when my baffle fell out, there was more top end, and an increase in throttle response. my bike still idled fine, but that's probably because i blueprinted and ported the motor, so it could take advantage of the free-er exhaust flow.
it was waaaay to loud for the streets of so cal, though. it sounded like a dirt bike. just sitting at a light had everyone in their cars giving me the stinkeye.
i'm still thinking up ways to make an adjustable baffle system, kinda like a supertrapp muffler, but that's not really high on my to do list right now.
i'd love to make it whisper quiet without sacrificing any power...
42blue15
136
St Louis metro, USA
Your thoughts?
As others have pointed out, if your engine is a 2-stroke, it needs a muffler. The muffler actually helps the exhaust get out faster than it would otherwise, believe it or not. You would be wise to look around for topics about 2-stroke muffler tuning and mods. Tuned 2-stroke exhaust pipes/mufflers start out thin, flare out to a fat section and then reduce down to a thin section again.
Engineering Acoustics/Sonic Supercharging of 2 Stroke Engines - Wikibooks, collection of open-content textbooks
If your engine is a 4-stroke, then yes, you can run it with just a short straight pipe, or even no pipe at all--just exhaust blasting out the cylinder head opening--because 4-stroke engine use the piston to actually push the exhaust out. The muffler on a 4-stroke may slightly increase flow (on a multi-cylinder engine with a properly-made exhaust header) but mostly just reduces the noise.
Do note that the vintage board-track cycles had the pipes to guide the exhaust away from the riders' legs.
Cabinfever1977
2,288
Upstate,NY
You could use a longer pipe and a straight threw non restrictive muffler,like the lawnmower ones or you can mod your stock muffler. So yes it needs a pipe and muffler but it dosent have to be a restrictive one.
A adjustable muffler would be nice.
Homeless Bob
43
Louisiana
Ok... I think I understand what is being said here... so am I correct to assume that if I put on an expansion chamber then come off the back of the expansion chamber with a short pipe and muffler I should be OK???
Or will the extra pipe, free flow muffler etc. lower the backpressure too much?
Hummm....
toker_ace
476
alabama
have you ever heard these little motors without a muffler? Geezz! My chopper had just a straight pipe from Barry and it was awfull loud!
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
The pressure wave keeps the mixture in the cylinder somewhat, but it does not push the piston down, that's from the combustion.
donutguy
230
PA
I gotta go with the quiet option....I am going to use my bike to commute this year-I get home from work at 4 AM-I really don't need to tick off my whole neighborhood :)
