Electric generator
Hi i am posting this thread so i can help more enthusiasts i tried to make an electric bike system because i drive a lot in the evening and with a regular lantern i don't see much and i have to change batteries often so i decided to use the engine to drive a bike dynamo 6 volt 3 watt I welded two washers to fit the belt into the wheel of the dynamo and two more at the crankshaft outlet on the magnet side I think it worked out well I idled it giving about 5 volts and with slightly fed gas it reached 10 volts to 1 amp no p is feeling a lot of power loss when starting cut a hole in the lid and the lid itself in half to get the washer not to interfere with the lid of the dynamo itself I made a stand of sheet metal and hung it on the side of the bolts holding the crankcase in place of bolts I twisted two studs I think it worked out well!
Hello, I have not completed the bike yet but when I finish it I will upload a video of how I made the whole electrical system!
Nice job man, it actually looks like an old motorcycle engine with a generator on it. I've also seen people run it off the back wheel( running a small wheel on the sidewall of the tire) and also mounting it to the seat tube and using it as a tensioner for the drive chain. Both of these would need the bike in motion to make enegry..
Yes, I thought I would mount it on the hood, but it won't charge in place, and it works like it does with cars when the engine and generator are turned on.
The generator itself does not have enough power to directly load the headlamp load the front is 600 lumens 15 watts and the rear is 6 watts without any battery will not become charged. 5 to 9 volts depending on how much gas you supply and only 1 amp.
