Testname111
Hello I'd like to show off my 2-stroke brushless alternator
I cut a hole in the gear box and removed the original screw then stacked up washers on a longer 8mm 1.00 pitch screw from the hardware store, attached the pulley gear, attached it all with washers and extra bike parts laying around,
These motors are waterproof and dust proof been riding mine with little to no problems after I got the belt aligned to the gears!
Powers my headlight with Max brightness with no batteries while running
OK. So as you can see I put this hobby brushless sensorless 3 wire motor.....3 wire = 3 phase A/C
Witch can me rectified
Any brushless sensorless motor should work
(Brushless sensorless motor)
Any 3 phase rectifier up to brushless motors volts should do 24v?
REMINDER any A/c voltage rectified should be half, so a brushless motor that produces 24v A/c (while spinning) should rectify to 12v D/c
(3 phase rectifier)
(USB Buck converter)
You will need a 5mm 20 tooth for the brushless motor shaft and a 8mm 60 tooth for the clutch side gear
(3d printer pulley)
Amazon.com: HobbyStar 4092 4-Pole Brushless Sensorless Motor, 1/8 Truggy/Monster Truck - 1730KV : Toys & Games
www.amazon.com
(3 phase rectifier)
4Pcs SQL50A 1000V Rectifier Bridge Three-Phase Bridge Low Frequency Rectifier Bridge Pack: Amazon.com: Industrial & Scientific
www.amazon.com
(3d printer pulley)
