motorhedfred
Not sure if this series of pics was intended to be a pole, but my vote would go to seat post oriented.
MHF
MHF
MHF
MHF
I like this one and thanks for the pics as was thinking about doing a similar mount.Per motorbicycling's request, a couple more pics of mounting options, this time with wheels on to give some sense of level.
First is the engine with mounting oriented to the seat tube:
You would have to use a small bicycle size chain ring.
This orientation would be the easiest to make a mount for the engine.
Does anyone have any thoughts on a dipstick with the engine mounted this way ? The other dipstick location isn't drilled and tapped on the 99cc like on it's big brother 212.
MHF
Sure, if you can find hose barb big enough to fit the fill neck. It would take a long time to fill up using that little drain hole. If mounting to the seat tube, I would put a pipe inside to add support to the seat tube. I have cracked seat tubes before.
Since the front forks are bent, I had to get a new fork. Thought I might go with the Suzuki K10 fork, but after looking at the cost of all the additional little things needed to make it work, I decided to look for a simpler option. After a mornings worth of web searching, I found a used "Nirve Spring Action Threaded Cruiser Bike Fork (Chrome, 1 1/8-Inch Threaded)" for $17.00 shipped. Thinking I might get a set of the bikeworldusa 2.125 wheels and a front drum brake.
Too bad you are not close, I have an extra set of dyno triple tree forks. Just so you know, look for 1 1/8 thread less That way you can use that nice stem
Those type of forks look really cool on cruisers. Keep in mind though you really dont get full damping on those, its more of a change of angle.
I've ran both, the "springer" forks dont feel as solid to me as the rock-shock style at higher speed.
Plus, i like threadless headsets, and "springer" forks dont come like that (whem I looked I coulden't find any).
17.00 shipped is a smokin deal!
