double brake handle
double brake? you mean squeeze one handle and it engages both front and rear brakes? I'd like to hear more about that. I am riding with only rear brakes
oooh, that's ugly man... i wonder if i could modify my current lever
do you think its possible?
Here is an easy way to do it if you have access to some material and a drill.
I can testify that the factory dual pull style like cruiser posted are not ugly and they work great. I've been using mine for months.
I rigged the front to the inner most pull and the rear pull to the outer. Pretty easy to adjust for perfect balance. Your variety of hand lever may not accommodate the Ghost0 2x pull.
very easy. took more time to get the grip of the handlebars then to mount it and adjust it
I use a little silicone spray and compressed air. Be sure to clean the lube before re-inserting.
Found a good way to get off old hand grips, just slide a thin long screw driver between the rubber and handle then lift slightly and spray WD40 in with the tube attached to the nozzel. The grip will slide right off.
