Large Filipino
I need a little meeting of the minds here. Look at the pics below for reference.
I have just a coaster brake on my Trike and the other day my chain derailed and suddenly I had no brakes whatsoever.
So up front is my Worksman fork designed for my drum brake wheel and no provision for a caliper or V brake whatsoever.
So replace that fork? Sure except that Worksman fork stem is way too long. I couldn't find my ruler so I used a string but you can obviously see how much longer that worksman fork is.
I also though that maybe I can simply cut the frame tube down to accept another fork but there's a reason for the long length and I don't want to compromise this frames integrity so unless I find a fork with a long stem this fork stays.
And the drum brake wheel sure I can simply install that back on,lace up the sprocket and call it a day but that sprocket isn't 100% true,and it's coming off the hub.
I'm about to get my 3 speed on there and although it's a coaster there's no way I can get it to work up front. I did look at that one mod someone did to a swing bike converting a coaster to a cable brake but I know these 3 speeds are complicated in there and I don't even want to deal with it so that's out.
I also thought maybe I can have someone weld me some bolt stays for a V brake up front but these forks are rather thin as it is.
Then I thought maybe a cable brake for the rear axle. At least if my chain ever derails again I still have that.
There has to be a rather inexpensive fix for this. How do lawn tractors slow down besides engine braking? How about go carts? Is there a way I can install cable brakes on my rear wheels?
(The rear wheels have no frame going around them)
