deacon
minor bike philosopher
I have come up with what I hope is a good next plan. First of all back to friction where I can handle the chain run and other factors more easily.
I have a 22 tooth rear coaster wheel sprocket attached to a motor. This is purely a concept bike.
Th the drive axle I will have an eleven tooth sprocket, Which is about and inch and a half in diameter. The drive wheel is three plastic caster wheels attached to each other with jb weld. the bearing for the drive wheel axle is going to be two skateboard wheels attached to the frame. The drive axle will turn through them making use of their bearings.
Chain tension is managed through a two part motor mount. The motor is on a platform and the drive axle is on a different one. The are attached in a upside down V configuration. ALL the pressure and torque should be tightening the chain not loosening it.
I'm using my funky test bikes on it.
the plan is that the larger wheel on the motor will make up for the loss of energy in the chain drive. With a little luck it will deliver a similar number of rpms to the drive wheel as it would in a straight run.
Once the motor drive combination is working, I am thinking of getting a mountain bike to put it or one like it on. A mountain bikes gearing would allow me to help the motor at a higher speed threshold and hopefully make the experience easier.
Now why I am doing this over and over. My wife and I were talking about this last night. Other than I'm crazy obsessed not to be beater by a piece of metal, I have a plan.
I want to design a bike that a retired person who is reasonably fit could ride to the grocery store. Most of you know that there are retirement housing areas for seniors. Lots of them don't get enough exercise, and many have lost their mobility because a car no longer makes sense.
The weed whacker bike was my first foray into smaller bikes. I had a lot of fun with it but at the end I realized that for ME as well as anyone in a similar situation it would not be realistic. To many nic picky issues arrive with so complicated a bike. I'm not saying this is purely a humanitarian thing. I want that kind of bike for myself.
When I finish I will hopefully have a bike I can ride five miles with a minimum of effort and then be able to ride home again. Five miles will get me anywhere I need to go on a regular basis. Also it will get me some exercise since the motor will only be a helper motor not a drive engine.
I think I have the basic design down, Now it is just check the components.
And oh yes I do fail a lot on this silly projects, but I pass a lot of time I would otherwise be filling with fast women and slow horses. I know that is a fantasy these days.
ill just get my dad to braze the bearing shut so it is stiff mite work 4 me?
