Damaged cdi??
Jason Lemons
44
Motor has been running fine for a month. Replaced clutch pads and installed back sprocket adapter. In the process I disconnected the cdi to reroute wires. When I reconnected it I hooked blue to black and black to blue. I noticed the problem after trying to start 2 times. Switched the wires back the right way. Now the bike doesn't run right at all. Idles fine but when I try to rev it bogs down and dies. Switched plug and adjusted carb to run leaner but only helped a little. It will idle put appears to flood when I try to rev it up. Any chance I damaged the cdi??
crassius
4,032
158
USA
guys come into shop often with wires backwards - never seen it hurt CDI - OTOH, CDIs go bad a lot for no reason, but usually don't spark at all
Jason Lemons
44
I have the speed brand carb. Could something just have suddenly gone wrong with it? I'm at a loss now. I use this bike to get to work. Any ideas would be appreciated.
crassius
4,032
158
USA
certainly doesn't sound like ignition problem - I always do a compression check first, but for this I'd also check if muffler got blocked, if clutch is dragging a bit, or if carb jet is blocked
  • Like
Reactions: Dan
Eric Matson
9
75
Check the fuel fuel bowl the main jet is extremely small and it doesn't take much to plug it
