Motor has been running fine for a month. Replaced clutch pads and installed back sprocket adapter. In the process I disconnected the cdi to reroute wires. When I reconnected it I hooked blue to black and black to blue. I noticed the problem after trying to start 2 times. Switched the wires back the right way. Now the bike doesn't run right at all. Idles fine but when I try to rev it bogs down and dies. Switched plug and adjusted carb to run leaner but only helped a little. It will idle put appears to flood when I try to rev it up. Any chance I damaged the cdi??
