Let us know how your MIG welder works on copper. I'm very interested.I had used screw together copper pipe that adapter made connection to the size thread on Briggs engine / muffler.
The replacement gasket from the rubber part was to be fiber high temp washer, but they did not last. I am making copper gasket to seal now.
Can't say it is the cheapest, but does not require welding and although I have a mig welder it does nice weld, but not on very thin metal. Even with setting available not a chance, til maybe I get an oxy acetylene set up and can silver solder.
http://motorbicycling.com/showthread.php?t=29678&page=6
Can copper hold up to the job of being an exhaust system? If it can how would one go about putting it together?
I would think there is a flange to thread adapter that you could then get a thread elbow 90 degree and go from there. You have to check if parts fit together and also fit on the frame too.
MT
I read somewhere a 90 degree turn could hurt power (gases dont like sharp turns), though if you're just looking to get it running, then it's fine. But yeah, I think one to three solid pieces of steel would hold up alot better than copper would, plus I could bend it, then weld it into one solid piece. If I knew where to get sheet metal in my area I'd build my own exhaust like jag's.
really? I thought conduit was only plastic? I asked minute muffler here but they dont have pipe that small (what is it? 1 inch OD?)
