Can copper hold up to the job of being an exhaust system? If it can how would one go about putting it together?
Let us know how your MIG welder works on copper. I'm very interested.I had used screw together copper pipe that adapter made connection to the size thread on Briggs engine / muffler.
The replacement gasket from the rubber part was to be fiber high temp washer, but they did not last. I am making copper gasket to seal now.
Can't say it is the cheapest, but does not require welding and although I have a mig welder it does nice weld, but not on very thin metal. Even with setting available not a chance, til maybe I get an oxy acetylene set up and can silver solder.
http://motorbicycling.com/showthread.php?t=29678&page=6
As you can see in my picture my exhaust port comes out the side of my engine so I need to do a sharp bend to be able to route the exhaust. This is some of the reason I asked about copper as I don't know if I could bend EMT conduit that much.Can copper hold up to the job of being an exhaust system? If it can how would one go about putting it together?
Yea not really building the exhaust just yet, but I am looking at ideas for it.I would think there is a flange to thread adapter that you could then get a thread elbow 90 degree and go from there. You have to check if parts fit together and also fit on the frame too.
MT
How about a muffler shop for steel tubing?I read somewhere a 90 degree turn could hurt power (gases dont like sharp turns), though if you're just looking to get it running, then it's fine. But yeah, I think one to three solid pieces of steel would hold up alot better than copper would, plus I could bend it, then weld it into one solid piece. If I knew where to get sheet metal in my area I'd build my own exhaust like jag's.
There is 1/2", 3/4" and 1" plus larger sizes of it in steel called EMT.really? I thought conduit was only plastic? I asked minute muffler here but they dont have pipe that small (what is it? 1 inch OD?)
