cobrafreak
My 2 stroke engine seized after 1250 miles. Not too bad for a two stroke I guess. That works out to .10 cents a mile. I pushed the button and ordered a complete four stroke kit. Not the 4G belt drive one but the grubee with the gearbox with the 3 big gears inside. I don't have it yet, it will probably be delivered in a week and a half. Bear with my stupid questions as I am new to four stroke:
1. Can I use the same 415 chain size from the 2 stroke engine?
2. I've seen others do this but want to ask anyway, can I remove the forced cooling shroud as it is a moving vehicle. Not the sexist thing around with the shroud on.
3. The ad for the grubee 4 stroke kit says the gearbox has a "wet run option". Does that mean it is possible to seal the gearbox to run with oil? If so, what needs to be done to do this?
4. I really like pedal start like my two stroke had. Is it possible to make the 4 stroke engine pedal start? If not what would need to be done to accomplish this? I would like to do this to delete the pull start lever for a cleaner look.
5. Any worthwhile upgrades or mods for the 4 stroke kit for more functionality, performance, or longevity?
Thanks ahead of time for the help people!
