Clutch stuck.
I know its late in the game to post, but when clutch action changes radically and it is not from cable stretch you might want to check the nut on the drive sprocket. It this nut comes loose the whole clutch assemble can receede into motor and then the clutch pin no longer gets pushed in enough to release the clutch (and there is probably gonna be some rubbing on the gear cover case by the clutch).
On time I had this happen to me, all the sudden it was like I could not pull the clutch in far enough to disengage the motor, I assumed it was cable stretch. It was not, it was the nut on the drive sprocket, it had come loose...
Also be sure to remove the clutch pin and ball in arm assembly and GREASE it well. Stops squeaking too.
