captainmorse
Nut or no nut, the gear and shaft should turn as one assembly due to the Woodruff key.
Take the gear off and see if the Woodruff is there or not.
My bet is that it is not, or else sheared. Get that taken care of, then shim the shaft with a washer or two, thread on the nut tight and be done with it.
Thanks Rohmell...will look into this next...I take it with the nut off the gear should slide right off?
