yeah thanks, found a lot of good info. sadly no dimensions yet.
so if anyone can tell me the diameter of the ball and pin, and the length of the pin, that will be a great help.
thanks in advance people!
5/16" is close enough for the diameter but the length is so critical that you're probably going to have to experiment. Those parts are available from some of the sponsors here but they can be easily fabricated. Venice's suggestion to use the shank of a drill bit should be followed because you want a very hard material. The pin length is going to be somewhere between 32 and 35mm. You might have to adjust for proper clutch operation. Round and smooth the end of the pin where it contacts the actuator cam and lube these parts well. Good luck.
