clutch lever
tredye
has any one had there clutch lever idle post stop working ,mine wont push down so you can pullin the clutch while its on the kick stand
Not too sure what your question is tredye. Are you speaking of the lock for the clutch lever?
YA ..Mines been doing the same thing . Its like there is a burr on it .
Just grab the end and twist it around untill you find a spot where you can push it in .
mabey smear some grease on it .
I think its coming out too far and getting hung up on the inside of the hole .
Probably needs to be taken apart and deburred .
( noooo deburr fo whan hundred eighty dahlah )
Yes, the body of the clutch lever the stationary part is "tin plate" and twists very easily. I straightened mine and now the pin slides easily in and out.
