Clutch Lever Problems
boylove35
I'm mounting my first 80cc. I'm having a difficult time with the clutch lever. It hits the handlebar when I squeeze it and the lock will not reach it's groove. Am I doing something wrong? Help Help Help!
FileStyle
719
7
Decatur,IL
I used a small cheater bar to bend my lever just ever so slightly , then took some snips and trimmed off about 1/8" off the lock mechanism. trim a little at a time , you dont want to take off too much ! the clutch lever is pretty cheap , so dont snap it!!!!
MrLarkins
HS Math Teacher
Jun 17, 2008
487
Arkansas
i didn't use the lever that came with the kit, instead I used my front brake lever (now I got no front brakes!) I keep the back brakes nice and tight
Gronkster
26
It sounds like you need to adjust the clutch more. Mine has about 3/4" on the arm before the clutch becomes disengaged. I think I remember pulling it in aways snapping on a vice grip and then tighten the stop nut.
boylove35
does the clutch have to be locked in all the time, oor after the engine starts can u relese it?
Dave31
11,199
47
Aztlán, Arizona
You have to release the clutch to start the motor, and to drive the bike. This is called engaged clutch.
If you want to stop, or just coast with the motor running, or push the bike with motor off; you disengage the clutch. (pull lever in or lock it)
