Dogtown Burner
new engine. same problem with both new engines i have. pulling on the clutch lever does not disengage the clutch. the acutator arm is fairly wobbly and loose. when I pull the lever, the cable pulls the arm until it stops parallel to, and against the case. the cable spring doesnt return the lever, and the cable is just loose and bound in the handlebar lever assembly.
I have read many theads that quickly go off topic, and do not answer the problem. seems fairly common. any takers?
