Clutch issue?
lucajo16
So Ive stopped at a light and it go's from red to green. I start to peddle and I release my clutch handle and then my clutch stops working. When I got home it wont engage and the wheel turns while the clutch is engaged. I'm using a 2 stroke kit please help!!:-||
Did this happen quickly, after one stop or did you notice the clutch slipping increasingly before? We need to know this before offering some suggestions.
I doubt the clutch cable is the problem. Usually if the cable slips you won't be able to disengage the clutch completely or at all. Only if the cable is too tight or binding somewhere would it cause your problem.
We might be looking at a broken or missing shaft key if the problem happened immediately.
yeah, clutches tent to fail closed except for a stripped flower nut or bent pressure plate (both of these rare)
--> disclaimer i'm still new,
I would take of the clutch box remove the flower nut screw, then depress your clutch and hold it, hand tighten the flowernut until the nut is hand tight, test your bike (before you put on the cover to save some time) if it works you should be good to go :D
