Welcome to the forum, did this happen suddenly? If so you may have shears a woodruff key under one of the gears, roll the rear wheel and watch the right side gears to see where the movement stops. The puller that comes with most kits will take any of the gears off if you're careful.
Yes this just started to happen. All i did was take it off 1 frame and put it in anotherWelcome to the forum, did this happen suddenly? If so you may have shears a woodruff key under one of the gears, roll the rear wheel and watch the right side gears to see where the movement stops. The puller that comes with most kits will take any of the gears off if you're careful.
Is it happening when going up steep hills, take offs or level ground riding? Is the new frame considerably heavier?Yes
