its a problem im having!!!!!!
beentryin,
Here's a series of animations that show how the clutch works.
http://motorbicycling.com/f30/animated-view-motorized-bicycle-clutch-assembly-8939.html
There is typically a little play in the gear...but like Al said; it shouldn't slop around.
Were there any small metal chunks in the case below the gear? If so...it may be what's left of the Chinese ball bearings.
I've had a few of these come apart. The ball bearings looked more like buckshot. Replace them with quality SKF bearings...and no more problem.
Jim
no there isnt no metal shavings in the bottom of the case,but there is play in the ring gear.its like its loose.beentryin,
Jim
Jim, that brings me to a question. Is there a way that the hub can be removed from the pad holder without watching 57 small balls roll all around the garage floor? ie..do you need to tap on the hub or what. I've never had to go that far. What about removing ALL the clutch pads, pack bearing grease into the bearings, clean up and replace the pads? Ever do that? I held the hub on mine and spun the gear, and for the life of me I can't figure out how this junk stays together....
Al,
Many of the kits come with a puller. After removing the large nut and washer from the center of the clutch assembly, you will see that the hub is threaded internally. The puller threads into the hub. Make sure that you bottom out the puller or the threads will strip. The shaft and hub are on a slight taper...so it may be really tight!
The ring with the small bearings, 3mm, is a press fit onto the flywheel. To get it apart and replace the bearings; I hold the gear and tap the three pins until it comes apart.
It's a bit of a PITA to change the bearings. You have to be really carefull when pressing it back together...you have to make sure that the ring with bearings starts straight onto the flywheel while also making sure that the gear doesn't shift causing the bearings to dislodge. The ring is hardened, and was not properly annealed...Very brittle!
Jim
