Ok, so I'm putting together my other engine for electrical mock up,
Go to put in clutch bearing, rod, and side panel.... only to see that the panel will not even close to screw on.
So I take stuff out, bearing covered in grease.... no problem, degrease, and use magneto and screwdriver to pull it out.
Problem.... bearing is jammed in
Can't get it out to save my life. Tried magnet, tried knocking on other side, etc etc.
I'm guessing this has happened to someone before, how do you get it out with out disassembling the entire engine/clutch assembly???
It's a 66ht
It's a 66ht
