Choke turns itself on.
motorizeverything
2
So after chasing countless air leaks, I finally got rid of them; however I have a new issue. For whatever reason the choke turns it self on now when riding, and it causes the bike to run way too rich and bog out. I wonder if there is some mechanical issue that is causing this or if it is merely that the choke rides up a little after each bump. Any ideas?
motorizeverything
2
thanks, that was it! I thought it was held in with pin from the looks of it, and that's what threw me off
lewdog7431
155
96
28
48
I've got the same problem with my stock carb the fuckin choke gets loose and rises closing off the air, like thr man said and it works ,a rubber band or a hair tie around the float and and the choke arm one twist of the rubber and it'll hold down
