shouldn't be too bad usually, if you can start bike with cover off and get back wheel in air, you can check for wobble in the small gear (factory often fails to get it seated properly on the tapered shaft)
note also that if noise is only when bike is moving, it may be chain rubbing under drive sprocket cover
