by far the easiest is to add to the header. start there adding like 5 or six inches, then try adding to the belly an inch or two at a time. with those cone angles being equal, there wont be a huge hit, but there will be a very obvious power gains. though not necessarily on the first try. the variable here is your exhaust port timing, but remember that the longer the distance that the pressure wave has to travel, the lower rpm the "power band" will be. with a 32 inch pipe, your peak power is somewhere around 13-14000 rpms.
I am very temped to buy this pipe,
im wondering if its necessary to actually extend the pipe? or should i just save up for the 2 stroke expansion pipe?
