Rockenstein
I was out the other night cruising with no particular place to go and my little engine is ticking along like a Timex at all speeds...I slow up for an upcoming traffic light and as soon as it was at the speed where the centrifugal clutch disengages it stalled out. I peddled it into a nearby parking lot that was well lit and check all the usual things like fuel, plug wire etc and still it just won't go no matter how fast I peddle or how much I choke it so I head for home which of course is now 7km away! I get it home and pull the plug...it's sopping wet and looking really fouled so I put a fresh one in. When I go to put the plug boot on it self destructs, tried to reassemble it but the plastic threads inside it that hold the brass part are stripped but luckily I had another boot I could use. I get the plug wired back up, kick it over and it starts...I let it idle for say 30 seconds in my shop and then shut it down figuring it's good to go. Next day I take it out back to the parking lot and get ready to warm it up before I set out on a venture to do a few things...starts right up and idles but it felt funny in that it just did not want to take any throttle. Not taking throttle when it's cold is sort of normal for mine but normally after about a minute of warming up it's good to go but this time after about 2 minutes it's still not liking throttle input and at about 2 1/2 minutes it just quits again. I lug it back into the shop and pulled the plug...looks ok, it's not sopping wet and not really smelling of gas so I pull the carb, disassemble it, blow out the jet, clean the bowl, etc etc and then reassemble. Kick it over a dozen times and nothing...pulled the plug and checked for spark and good looking spark we have. I'm thinking ok maybe I chewed up a crank seal so I put the plug back in, blocked off the exhaust port with a makeshift plate and ground down a rim valve so it fits nicely in the intake tube. I pressurized the crankcase to about 10 psi and brushed a thick soap mix around the seals and crankcase gaskets...not a bubble is seen. By this time I'm really scratching my head as to what the heck is going on so I get out my DVM and check the ohms on the winds of my magneto and compare with the info posted on here and the magneto is looking to be ok. Again I pull the plug and check for spark and I have spark. I also pulled the magnet rotor off, wiped it down, and the magnetism feels like it's good enough to generate proper current in the magneto. So the point I'm at now is all that's left that could be wrong is the CDI but I'm skeptical of that thought because in my experience electrical components normally work or they don't work...and I do have spark outside the cylinder. Right now my engine will fire briefly but will not catch and then idle at all like it was when I took it out to warm it up. I'll add too that I've checked the line from my aftermarket kill switch for a potential grounding out...also did the same for the plug wire and the wires leading to the CDI.
Has anyone ever had a CDI fail slowly?
