I hate fat chain (415) I find it loud, hard to work on, and overkill.
I'll take an HD 410 Diamond or KMC Z-chain every time but other than Skyhawks most kits ship with 415 sprockets so your screwed.
If it's your personal ride then no tensioner is best, if it's for someone else however a tensioner makes life much easier for them.
If you don't have horizontal dropouts forget it, but as mention if you can adjust the wheel back your set.
Also as mentioned if you have a deraileur on the pedal side it tensions itself, if not then you can add a 1/2 link to the pedal side if needed and put a tensioner there.
Note this is NOT ideal if you use the coaster brake!.
If your ONLY brake is the coaster brake then besides being a fool a tensioner on the pedal side will just make your inevitable crash because you couldn't stop come sooner when it fails.
No tensioner should ever be on the drive force side of a chain, for the pedal side it is not for pedaling in the above examples, but it IS the force side when you back pedal to slam on the brakes, especially in an emergency.
On coaster brake bikes I like to just put on a couple of caliper brakes with a dual pull brake lever so the coaster brake is just a 3rd emergency brake which makes this system pretty reliable and safe providing you keep an eye on your drive chain tension until it's broke in.
This isn't a direct drive no tensioner build as a tensioner makes it easier for the customer but adding good brakes is not hard or expensive.
The last thing most sane people want is something like this.
Then again there are still people that spend $500 on a motor kit and performance parts and then slam it on an $88 WallyWorld bike with just a coaster brake and ride wearing nothing but a swim suit and flip-flops.
You don't see many of them on the forums, they usually end up on the Darwin list before they have a chance ;-}
