harry76
Ive had a look online for a centrifugal clutch, but all o have seen are clutches with sprockets, but i need one with a pulley. Can u get them with a pulley? If not can i remove the sprocket and install a pulley?
Also can you put the clutch on either the primary or secondary drives?
As i only have around 45mm between the two pulleys on the jackshaft, so if the clutch is wider then that i may have to put the clutch on the secondary. Is that ok? I mean does the clutch engage by powering the shaft or also by powering the pulley/sprocket, depending where in the drivetrain it fits best?
I have a Villiers 98cc motor with a belt pulley threaded on the crankshaft so the clutch has to go elsewhere
