carb probs
joeselect
Engine is on bike started first pull then dies now cant keep running or even start without wide open throttle and gas is pouring out over flow tube pulled plug of coarse gas soaked dried it tried again throttle has to be wide open to get to even fire what can be the problem any help would be great thanks alot
Have you checked the float level?
here we go thanks
When you get the carb off the engine get a picture of it, like a side shot or maybe both sides.
What's gonna happen is you are going to enter the float chamber and check two things. 1. Is the float level about right. (probably is) and
2. Does the fuel flow shut off when the float raises. (probably doesn't)
A common reason for fuel to continue to flow when the float has raised is either a poor fit between the float valve and its seat, or some kind of crap has stuck itself to the face of the float valve or seat and won't let them stop the flow.
It's usually a simple matter of cleaning the valve and seat with carb cleaner in an aerosol can.
looks like one of the ""5G kits"" with the 142 hs motor
Sick bike parts has a carb upgrade for the 142 hs motor
thanks for the suggestions runnin good now seems to be idling good but snapped off idler pulley so im waiting for one to come in but thanks again guys Oh Almost Forgot what is the adjustment on the bottom of the carb for thanks
