Larry Trotter
Mods to get the engine installed and working: I shortened the rear mount about 1/2 inch, modified the large tube plate adapter for the front mount to allow it to fit better. On the rear wheel I cut about 1/8 inch off the axel shim on the right side and put washers on the left side so the rear wheel was shifted right about 1/8 inch for chain clearance to the rear wheel support arm. Removed the front shift mechanism to make room for the throttle and double pull brake lever. Moved the rear shifter to the left handle grip to allow the brake and throttle on the right side. Installed the double pull brake lever. Both the Gas tank and the spark coil are bedded to the frame using Shoe Goo or Goop, this stuff works perfect for this, easy to put on and rock solid when it sets up. It can be removed. Think this is about all that was needed. Larry
