I was trying to attach a new log exhaust onto the block the outside of the bolt hole had broken off. Is there away to repair it? I do have a gt90 kit that I can use to make changes with.
I broke both sides on mine ..what i did is i super glued both back on for which its just to hold them in place so i can work on it ..i then took a wire coat hanger and cut a piece off of about 5 or 6 inches...i then twisted both ends so each side had a loop in it...then i wrapped it around while forming it to the little area on top of exhaust port until each end of hanger are down each side of cylinder about 1 1/2 to 2 inches snd then put a good steel bolt through the loops of hanger and tightened a nut down forcing the ends off hanger to tighten around the broken and glued pieces...i did it 2 days ago and its still all good... I wish I felt would have thought of that sooner come up with something that worked... Give it a try... Worked for me, don't see why it can't work for you...G.L.I was trying to attach a new log exhaust onto the block the outside of the bolt hole had broken off. Is there away to repair it? I do have a gt90 kit that I can use to make changes with.
