johnsoma
Hi guys,
I ran a new engine twice and broke two heads in less than 15 mins. It was a prebuilt motor from ebay. Only thing I did was paint the motor with black engine paint and cook it in the oven to set the paint. Any chance the cooking at 500degrees hurt something inside??
After painting and cooking of the paint I slapped it on the bike. It quickly began making a horrible metal knocking sound once I got it running. And then cracked two heads in the process. I thought it might be too long of a rod and So I tried two gaskets and it still makes the metal knocking noise. From the noise and the fact that i keep breaking heads it makes me think that the piston is hitting the head and thus cracking it. I am clueless. Also when I remove the head and just crank the motor over using the pedal with clutch engaged it will spin over very smoothly and make no noise at all which makes me think that all the bearings are fine.
I took pics of both heads and gaskets. For the pictures I put little arrows pointing out the cracks in the heads. The gasket when on feels like it is hanging in the cylinder a little, it is not smooth transition up the wall of the cylinder and past the gasket. Could that be it. Pics of that as well. This engine has been running for less than 15 minutes on both heads and has cracked both of them. All of the pictures and videos together can be seen on my Dropbox at the following link.
https://www.dropbox.com/sh/byd4nuoircso55s/AADZMnSqdVACPP7ZGXDpBHlOa
Someone mentioned a blown rod bearing? would that make this sound but also allow it to run as mine does? How hard is that to determine if true? and fix?
I am thinking about just buying a whole new engine. Thoughts?
Thanks for the help,
Mike
Mike
