pulsar2121
In the manual I got with my 80cc 2 stroke kit it says:
I get a kick out of that last part. Anyways, 16:1 and 20:1 seems like an awful lot of oil to me. The lowest ratio I have ever heard of is 30:1. What is everybody else using for a mix ratio and what type of oil are you using? I am assuming ashless 2 cycle engine oil would be best in this case.
Also, about the speed and distance. I did the math and you are not supposed to go faster than 12.5MPH for the first 300miles. That sounds like something that could make the list of 1000 worst ways to die.
Again, what do you think is a good break-in procedure for this engine?
I think some meaning was lost when they translated the manual for this kit.
During run-in, keep the mix ratio at 16:1 for 500 kilometers and keep your speed down to a maximum of 20 kph and do not run your motor for longer than 30 minutes. After run-in keep a mix ratio of 20:1 and use high quality synthetic Motorbike.
