I had some idle issues at first too... I also recommend you not worry too much about it until you complete the break-in on the motor and start running a standard mix.
Couple things that haven't been mentioned here yet, an air leak could cause your idle to be erratic. You want to make sure the intake/exhaust manifolds are air tight at the jug, and the carb isn't leaking where it mates with the intake. Also, sometimes drag on your cables can cause your idle to change. You should put some light weight oil down in your cables to help them pull smoothly, and make your cable runs smooth and sweeping rather than tight and bending. If the cables are too tight when you move your handle bars it might cause the clutch to drag and bring down your idle or might make your throttle move. Finally, when my float was set too high I had problems with the motor dying when I hit bumps while the motor was idling....
