So Im in the plotting and planing stage of a worksman BTR I love Sportcarpats work but most pics I see the tanks and tool box/oil tanks ar affixed with what apear to be el'cheepo pressed aluminum pipe hangers from Home Despot (delebrate misspelling)
I wanna build a Brass age bike and that means brass fittings. Anybody know a source in brass of what Im talking about? Thanks in advance.
Being a advocate of DIY, these are actually pretty easy to make.
Simply put a piece of brass flat stock in a vise around a scrap of tubing that matches your frame. Cushion the brass from the vise jaws with a heavy piece of fabric or thin leather.
The flat stock should be quite a bit over length, expect some waste.
Bend the first 90° (easy) and then start moving and bending until you have a full 180°. Flip this “u” shaped piece over (still around the tubing) into the vise to the right depth and bend the taps away from center.
Be sure to subtract the thickness of your flat stock from the overall desired height before bending the taps. A rubber mallet may be helpful here.
Trim the taps to your desired length, round off the ends( ?) and drill.
12” pieces of this type of flat stock in various sizes can be found at any good hobby shop.
Although I’d recommend trying it cold first, brass can easily be annealed by heating to cherry red, then working it right after it has cooled.
After a while (maybe as fast as a hour, perhaps a day or two) it will return to it’s prior hardness. The more you work it the quicker it hardens again, re-anneal if necessary.
But like I said try it cold from the store first, because as while it’s annealed the greater the chance there is of maring or crushing it in the vise. On the other hand it may crack when you bend the taps, so annealing may be necessary.
Determining the correct height is the hardest part and you very well may screw the first one or two up- But there really should be a short learning curve here-
Good luck and post pics!
-Kirk
