Glad you're up and running but I hate to see you waste money. You have the best carburetor for a stock engine and the factory CDI will give you everything you can expect from that engine. The weak link is the spark plug boot. Get rid of it and replace it with a good automotive quality boot. That will require that the spark plug retain the top cap. There are spark plug alternatives to the kit plug such as the popular NGK B6.Hey everyone,
Thanx for all the great advice. I found two problems; one, found a small chunk of teflon tape in the carb jet (who knows how it made it through the filter and two, the CDI on the boot side I suspect was loose. It's not the screw type connection but the spring type which is sqeezed into the wire. Either way it is running again so thanks once again. I am going to invest in a better CDI and carburetor.
