Bigger Gas Tanks
>ScCruisin<
Does anyone know of any good tanks that are maybe a gallon or more that can be easily installed
without any modifications, that just screw on like the stock ones? Maybe that wrap aound the frame? And also, can you put wider tires on your cruiser for a smoother, more stable ride?
Cheers
first id like to get a smaller tank with a petcock,something that dont look like a football that the stock tank looks like.second my scwhinn delmar cruiser already has wide 2.125" tires front and back any wider and there wont be room for a sprocket or anything and any wider and there would be clearance issues with the chain.
ive got fat nobs on my back and flat city crusers on the front i have no prolems with it at all but you have to keep tires hard back tire is a 2.275 and the front is a 1,175
where can i get a 1 gal. gas tank got a 80cc im mean theres notting wrong with it i just want to go the 150m to the gal. to the beach and back ie so cal thanks
stock tanks are 3/4 gallon... you could create a 1/4 gallon reserve with a 2nd smaller tank zip tied to the frame. could use a soda bottle and zip tie it to the frame.. hose running in, and hose running out the bottom to the carb.. seal the bottle up with silicone so it don't leak.. silicone good gas line in it and not the cheap plastic stuff from the hardware.. only trouble is, you would have to open the petcock to get it filled first, then close it and refill the tank.
Stock tanks are 2 liters, so 1/2 a gallon...
Some will hold .6 gallons. I've never seen one that will hold 3/4 gallon.
There is a 4 liter tank available on ebay. (1 gallon)
'BrettMavriK
'BrettMavriK
the tank that came with mine is listed as 3/4 gallon.. who knows if it really is.. I didn't measure
BoyGoFast on ebay has some bigger tanks. There are a couple other 1 gallon tanks out there as well. I'm waiting for "ghent" and his tanks as an option.
Im using the 1/2gallon stock tank but i want the opposite,id like a smaller 1-liter tank.
i get 90 miles per tank right now,i never go that far,half that would be fine. I only put 1-liter of gas in my tank right now anyway.
