deacon
minor bike philosopher
I just might finally have this bike together.
friction clutch is no more than the motor on a hinge. A cable from the extra brake lever (tossed out the adjuster so it was full throw, thanks to bike guy joe)...
I cut off all but three inches of the sheath and ran the pure cable to the front of the engine mount. The brake lever at full throw seems to lift the engine just enough to disengage it. To adjust it I simple rotate the lever on the bar. I can tight or loosen it quite a bit. I also removed the hex nut and bolt which locks it to the handle bars. I replaced it with a quarter inch one. I used quarter inch for everything else so it is easier to work on should I be out when it needs adjusting.
I finally got the right spring so it will pull all the time not skip and yet not so much that I can't lift the engine. I need to test ride it on a the long test course a little later but it seem to be just fine.
I think it will pull most of the hills without pedaling but I will probably do so now and then anyway to keep the speed up a bit.
