Skyhawk 66 cc, spookytoothcycles...is what i bought and where from, also, bought a cns carb.
When it first started running...it ran great....i swear. I got on it today it ran great...i thought to myself i should go on a short ride..I'm breaking it in by the book btw. Im running 2 cycle royal purple with 93 octane at 20:1 ratio. with that out of the way here is the problem.
All the sudden no power..at all. I was going up a small hill at 8mph manually then i engaged clutch gave it a bit of fuel and killed it because it wasn't working. I thought it surely must be to much load. So i went down the hill engaged clutch..same problem no power. The engine will turn over and run as long as i pedal. when i stop pedaling...so does the engine. The engine will not idle. It did yesterday..
I called spookytooth, followed their suggestions on the cns carb..which was as follows. idle screw all the way in, air/fuel about 3 turns out. remove pink tube. I did that...no help. They said put on stock carb. Didnt work. I'm not sure its the carb. It's like it's not catching something i dunno it's very odd. Im really hoping some one will know these symtoms and be able to help.
