Flight Risk
I have a Grubee 48cc and have the instaltion mostly finished.
First questionI have the clutch adjusted according to the directions and when the clutch is pulled all the way in, there is a lot of drag, and seems like it will be a pain to pedal.Will this loosen up after it is ridden a bit? I have searched the threads, and found out about a flower nut. Should that be adjusted on a fresh motor?
Also I am considering shorting the throttle and clutch cables, as they seem to bind a bit no matter how I try to route them.
Other than that, I think I can gas it up.
thx
Rod S
thx
Rod S
