Bikeguy Joe
Looks like your base gasket was leaking and it ran lean. How long have you had it? Talked to the seller (warranty) yet?
lean, i keep hearing those kind of words...lean means too much (oil, gas, fuel, air) PICK ONE please.
You are definatly lean... Look at the pic of the spark plug, Might want to raise the needle in the carby (lower the clip) one slot......Parts all look ok though. Also when you put the piston back in the cylinder make sure you line the opening of the rings up with the little pins in the grooves...
8oz @ 20:1 = 160oz of gasoline 128oz = 1 Gallon So 8oz of oil to 1 Gal and 1qt of Gasoline
Any QUALITY oil..... I use Amsoil Sabre....
In this post Norman shows you the internals of the carb. You need to read it an familiarize yourself with it then you might want to try moving the clip ONE notch and riding your bike and see what you think. And then MAYBE try another slot and TEST RIDE ETC. Looking at that spark plug I think you are running lean so you should start with moving the clip DOWN 1 slot to increase fuel to air mixture....
http://motorbicycling.com/f4/carburetor-pictures-how-install-rebuild-195.html
i also moved the 'c' clamp to the lowest position in the carborator...isn't that suppose to give the most oxygen in the mix? i don't think i'm getting maximum combustion...lots of oily black on plug...and i mixed 4oz 2 cycle oil with 1 gallon gas, that's the right mixture, right?
no, someone told me to move it down 1...so i did, then i went down 2...when i get home (at work now, goofin off ) I move it up and post back
here's the guy MISTERIGHT2_99!!!
Read the first paragraph one more time CAREFULLY!!!!!!!
misteright1_99 said:you might want to try moving the clip ONE notch and riding your bike and see what you think. And then MAYBE try another slot and TEST RIDE ETC. Looking at that spark plug I think you are running lean so you should start with moving the clip DOWN 1 slot to increase fuel to air mixture....
hmm, i read it 3 times, and I still read the same thing...
it still says move down 1 slot, as I did...pablo says move to top spot (up, not down)
what am i missing? now i'm really confused. heck, i'll just try all slots!
MrLarkins said:...it gets more gas (hence the black, oily spark plug), .......acts like its flooded.
i'm getting it now, but thats confusing...more fuel...lean? how bout, more air or less fuelpablo said:more fuel lean
ok, i am such a noob...you guys are a bunch of help! top notch it is
and just for the record, the wording lends itself to be confusing...i mean really...
Pablo said:It's gonna turn out that your issue has nothing to do with the needle groove.
