MotorBicycleRacing
Did you remove the valve cover and do a check?
From your description BikeBerry should warranty the motor.
What happened was as I was riding it, it made this loud screech all of a sudden and bogged down and died. I pedaled it to the closest gas station and started inspecting it. Nothing abnormal so I tried to start it and the rope wouldn't budge. I called Bikeberry and told them this, and they said to take off the pull start unit and inspect it, so I did and nothing seemed to be wrong. Replaced the pull start unit, tried to start it, and it did fire up. It sounded good too, like it did all along. So I tested it out around the block, and all of a sudden it went POP!! and I stopped and looked down and smoke was coming out of the air cleaner. I knew this was bad, possibly a stuck valve, maybe broken. Something big. Tried to start it again, and it spins, like I can hear the crankshaft and piston moving, but there's no resistance, it just spins. There is no weird sounds coming from the case when I tilt it around, like metal bits or anything. It just spins now. Spark plug is in there good, so thats not the problem.
