"Adventures in Pull Start - Centri"
1st- Gahhh! K, I feel better now.
So when I first dragged the bike outside, the centri was sticking... more on that later...
Put some fresh 24:1 mix in the tank and it started on the fifth pull, and the cable broke at the same time... lol. Took it apart, replaced the chincy pull cable with a brake cable, and while putting it back together the band spring decided to unravel... Clamped the plate in the vise, vicegrip on the outer spring catch, small vicegrip on the inner and rewound/tightened it back into the plate(what a pain in the butt). *carefully* reassembled it. In the handle the chincy cable had a knot on a nut, so I tried an old brass nib from a clutch cable. Over tightened it, and the nib split in half... d'oh! Tied a knot on a nut. Now that's solid.
The carb that came with the kit would only run with full choke. No air leaks. Noticed when changing the C-clip the needle is almost flat at the tip... will worry about that carb later(check jet and whatnot). Spare carb went on, fired up and ran great. Chain was a bit wobbly, but stayed on track. It'll need a spring tensioner to take out the 'slap'... It's a crazy long chain. Two full lengths and over a third of another.
Then I realized...
Even at idle, the centri didn't go to neutral... gah! First I tried applying the brake when giving it a little gas, but no luck. So I take the cover off from over the centri, and its not centered in the bell and binds up. Even turning it over with wrenches(one on sprocket, one on clutch) It's binding in one spot. The clutch itself works like advertised, pads in at idle, out after some rpm. So it's not like its not disengaging, just binding in that one spot.
So in the morning, have to get a thread puller to get the clutch off. Will take a grinding wheel on the dremel to the bell to clearance it...
Then all should be good
What a headache of a day though... arrgh! Big storms supposed to kill the rest of the week, so was hoping to get a shake-down run in while it was nice. Oh well, next week's another week
