KCvale
What the heck, the shifting gas Fat Tire was a hit and looking for another Fat Tire I ran across this.
Mongoose dolomite 7-speed with dual disc brakes and 4" wheels.
It was $375 delivered, much less than the Sun Crusher gas Fat Tire so what the heck.
http://www.farmandfleet.com/product...tMZIsFQvIToaisOG-opgrndsUc0dL7ycdgaAp378P8HAQ
I am using most of SBP 48V kit parts and some of my own fabricated stuff.
http://www.sickbikeparts.com/catalog/product_info.php?cPath=26&products_id=181
Cyclone-e-bikes CY-650 ~1680W 25-48V 2255-4500 RPM BLDC motor.
Kelly KBS48 101L-L Programmable Controller 48V - continuous 840~1680W, 35A continuous, Max 100A 4800W
EM3ev battery pack with 110 18650 lithium Ion batteries with an excellent BMS (Battery Management System) in a triangle configuration for mounting in mountain bikes.
Smart battery charger with 3 settings, 50% charge for storage, 90% for most uses to extend battery life, and 100% 54V charge for when you want to go crazy.
The drive train is almost done.
It took some special mods but we have it in.
The motor has a 3 point mount via re-tasking an unused 2-stroke muffler clamp at the top.
With a little paint and magic the spring loaded tensioner almost disappears.
That was the easy the part, the hard part was the BB and mounts.
The extra wide BB only has 2cm of threads in so I couldn't use a nice wide needle bearing cartridge and had to use the stock caged bearing shaft and bearings.
With the drive side motor mount taking some bearing cone room thus moving the axle there wasn't enough left to put the other motor support mount on the bearing cage.
We ground out (in this picture) the right side bearing mount hole to slip over the outside of the BB, then made our own custom spacers with standoff nuts, pieces of an old bike rack, and bolts.
We also had to get a little creative with the freewheel sprocket assembly.
Getting the inner sprocket to the back wheel to fit past the fat tire when in first, and the motor drive chain to not hit the wheel drive when in 7th just required some spacers between the FW and sprockets.
Next up is the handlebars so I have a throttle wire and then mounting the controller.
