16v4nrbrgr
You might be able to use a front freewheel crank with an extra sprocket to accept power from the motor. If a frame mount will make the combined drive train easier, maybe one of those HuaSheng 4stroke expando mounts could be made to work.
You're really smart using derailleurs instead of geared hubs. I think geared hubs are a weak point that's a pain to fix, and a good derailleur is trouble free and strong. The geared hubs are only really a packaging advantage and the shifting when sitting still. I think if I ever do a mountain bike it'll be running through Shimano derailleurs, maybe a 4 stroke so I can get away with some trails if its quiet like a generator unit. I think for a practical non-toy bike this is THE way to go for reliability. I haven't tried running the hubs on a jackshaft at higher revs to reduce the loading, something I'd like to try but I doubt it is more reliable than a derailleur. Hubs aren't the best for shock loading too, something a regular bike doesn't have a problem with. The new rapid shifters work so well its amazing.
I'm interested in seeing how it turns out. If that little motor has mounting points on the bottom you might consider in-framing it because I think all you'd have to do is drill some bolt holes in the HS mount. Then the chain for the motor to cranks would be really short.
