worksuxxx
Looking for some advice on putting together a top engine mount for a 4 stroke. I have been experiencing a vibration at a particular rpm and finally pinpointed the problem. I am getting slight engine movement causing the vibration. The heavy duty mounting plate is correctly installed. Bolts are as tight as they will get. When I idle up to the rpm where the engine vibrates, I tried prying from the bottom of the motor to see if the vibrations change, they do not. When I pry from the top of the motor just slightly, the vibration stops. So I need to figure a way to get a metal bar mounted to the top, but not sure where to mount it to(no head bolts). Anybody ever add a bar or strap to help out with vibration? Not looking for a rig job either, must be appealing.
