I need to clarify some figures, was pulling them from my memory, not a good thing to do at my age. Had the specs from my battery mixed in with my speed control and the BMS. I have a 48v 15ah battery rated at 100amp bursts and 30amps continuous. My speed control is rated at 20amps max with 15amps continuous. The BMS is rated similar to the speed control. My system is relatively mild one, limited by the BMS/speed control basically. The motor in the SBP kit is a pretty hefty consumer/powerhouse. Im sure it will preform best with the recommended battery, but you could operate it on anything even SLAs with proper management. When you buy a battery see if it has a BMS and what the rating is, that can be a limiting factor even with a bigger battery.
Sounds like an interesting build. Have fun!
Good info, thank you.
Im looking at Ping batteries and they do come with a BMS.
Specs on the 48v 10ah
Specifications:
Suitable Wattage of Motor: up to 550 Watt, 450 Watt suggested
Applications: E-Bike, Electric Bike, E-Scooter, Electric Scooter
Voltage: 48 Volts
Capacity: 10 Amp Hours
Dimension: 200x105x150 mm / 7.9x4.1x5.9 inches
Weight: 4.90 kg / 10.8 lbs
Charging Voltage: 60-61 Volts
Charging Current: <5 Amps
Rated Discharging Amperage: 10 Amps
Max Continuous Discharging Amperage: 20 Amps
Maximum Discharging Current: 40 Amps
Discharging Cut-off Protection: 30 Amps
Lifecycle of the whole pack: >85% capacity after 1000 cycles. Lifecycle of single cell: >85% capacity after 1500 cycles, >70% capacity after 3000 cycles. (<1C discharge rate and <1C charge rate)
Specs on the 48v 20ah
Specifications:
Suitable Wattage of Motor: up to 1200 Watt, 800 Watt suggested
Voltage: 48 Volts
Capacity: 20 Amp Hours
Dimension: 195x210x150 mm / 7.7x8.3x5.9 inches
Weight: 9.90 kg / 21.90 lbs
Rated Discharging Amperage: 20 Amps
Max Continuous Discharging Amperage: 40 Amps
Maximum Discharging Current: 60 Amps
Discharging Cut-off Protection: 50 Amps
Jim from Sick Bikes e-mailed me and I will quote him.
I don't see an issue using the 10 ah battery as a back up. You can view batteries this way. The voltage is similar to the type of fuel and the ah is how large the fuel tank is. So a 48v and 20 ah is the same as a 48v 10 ah except 10 ah is only half the size of gas tank. So basically it will just run about half as long. Of course there are C rating and such but this is a good generalization.
Im still worried about overheating a 10ah battery if Im in the woods with hills and rocks and stuff but I guess that's what gears are for.
I better start ordering something soon with the anticipated long ship times lol!
Dan.
