nope. no spark. checked everything with multimeter, past the cdi i get no reading. i'm not sure what would have burnt it out. it's sealed - there's no way water got in it.
The chinese grease does smell bad but if it smells like fuel it's not normal and you might have a clutch side seal failure. When that happens you will notice oily stuff coming out of the crankcase throught the seal, it might be hard to see since it's behind the small gear but in most cases you will an oil film sipping down under the gear; I mention this because a seal failure can let air in and primary compression out making the engine underpowered and prone to failure.I also noticed when I pulled off the clutch cover there was quite a bit of strong smelling dirty oil/grease (maybe gas mixture?) on the inside of the cover.
Just go to a local bicycle store and buy a cable from them that is long enough. The inner cable and the outer cable housing that comes with the kit is crap anyways. You can get a much better cable from a bike shop, a better cable will also help reduce the amount of force required to pull in the clutch. Just ask the bike guy about cables and they should lay out the differenced for you, the lined ones work real smooth compared what comes with the kits. If your worried about it being strong enough or the right length just bring what's left of your old cable with for measurements...Bought a replacement cable on ebay....
Sounds like good advice, I'll give that a try, thank you.Just go to a local bicycle store and buy a cable from them that is long enough. The inner cable and the outer cable housing that comes with the kit is crap anyways. You can get a much better cable from a bike shop, a better cable will also help reduce the amount of force required to pull in the clutch. Just ask the bike guy about cables and they should lay out the differenced for you, the lined ones work real smooth compared what comes with the kits. If your worried about it being strong enough or the right length just bring what's left of your old cable with for measurements...
Welcome to the forum ajslim...Can someone please tell me the right plug in colors? And what other spark plugs can i use for a 2 stroke 49 cc china engine bike kit engine???
